I havent had time to try anything so figured I could check in here. I used the Blucat trans tool and everything seems fine except an early 1-2 shift. Its set to 6600 but will shift around 6400. 2-3 seems ok.
What is the remedy to this? If i wanted to go to say 6800rpm i wouldnt want it to shift early there as well.
So what now? Raise WOT shift speed? Its def getting shift speed. Raise WOT shift RPM in 1st to see if it offsets?
Thanks guys.
Tune6_MAF_6600_USE.hpt
20-08-22 19-34-41.hpl
