Results 1 to 4 of 4
Thread: Code problems
    Code problems
    I have an 2007 mustang gt with an edlebrock 1580 super charger on it with it has long tube headers
    I'm getting the following codes: P2196 stuck rich and
    P2195 O2 sensor stuck lean
    P2197 stuck lean
    Also have the problem since the weather has gotten cooler, car wants to surge and stall until it warms up and then it will run fine
    Is there a way to tweak the O2 sensors in HP Tuners?
    I'm new to all this
    Nov 2009
    All Around
    3,149
    you will need to log idle, cruise so we can see activity of your fuel trims and post your file so any kind of needed correction
    Hi
    if you look at 12:55 :48 to12:55: 58 you can see where go down to 284 on rpn when cold
    Mar 2010
    New Orleans, LA
    630
    usually if one o2 goes rich and the other lean then you wither have them switched or have an x pipe and need to disable one
