Results 1 to 5 of 5
Thread: TCC locking up too soon
    Apr 2015
    18
    Hi
    I am tuning a LS conversion for a friend. its a 2003 burb 5.3 with a 4l80e added.
    The TC locks up as soon as you get into 2nd gear. Even though I have the 2nd gear table set to 255 and even tried 128 mph in case 255 was invalid.
    The only way I stopped it was setting the PWM duty cycle to all 0's. I tried copying the trans tables from my malibu cause that only locks up in 4th but it did not help.
    PCM is a P59 with 12579405 OS which appears to be ok for 8100 motors with a 4l80e so I cannot imaging the OS being the issue.
    The lockup will not release till we almost completely stop and the motor almost stalls. If I inhibit the TCC in HPtuner (VCM scanner) it will obey and stay off.
    I am trying to attach the tune. I seem to be doing it wrong. stand by.
    And thanks for any and all advice.
    Apr 2015
    18
    here is the tune
    I finally got the tune to upload
    Apr 2015
    18
    Hi just checking to see if anyone has even seen an issue like this one?
    Jun 2020
    6
    do you have any scanner runs? when he installed the 4l80e did he update the wiring for the 2nd speed sensor? Im assuming you did a segment swap for the 4l80e trans?
    Jun 2015
    253
    Did you do a transmission segment swap? Or did you just change 4l60 to 4l80 in the tranny settings?
