Results 1 to 3 of 3
Thread: What is the maximum amount of boost you can run on an E67 ecu?
    Aug 2008
    Chicago
    98
    Currently, running a 2.5 bar OS on an E67 427 twin turbo CTS-V and want to run more than the 22.5 psi limit of the 2.5 bar OS. Thinking of switching back to the stock OS which should be able to read more boost pressure. How accurate is the fueling on the stock OS running between 20-30 psi?
    2000 WS6 Trans Am LS3, Tick Performance Stage 2 cam, ARH 1 7/8" Headers, FLT Level 6 4L60e, Circle D 5c Launching on a 200K 10 Bolt
    2001 Camaro SS M6 Black on Black
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    Per the gmve you can run 315 kpa(about 31psi) using hptuners and the preset tables. Accuracy of the ve table isnt so much an issue as injector scaling.
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Aug 2008
    Chicago
    98
    Thanks for the input Michael.
