Results 1 to 2 of 2
Thread: 2009 ctsv with 4.2 Kenny bell out of maf range
    Advanced Tuner lt1z350's Avatar
    Mar 2014
    Dandridge, TN
    560
    I did an os swap on my 2007 Tahoe to a 2009 and was able to get things I needed with more range and was hoping someone has touched on this with the 2009 ctsv and it?s 85 lbs/min range on the maf. This car is on 25 psi with the Kenny bell and seeing upwards of 13,000 hz on a 5 inch maf but the 85/86 lbs limit is obviously a problem. I do believe the 2012 zl1 has much more range so was wondering if anyone has gone to a new 12 ecm or just wrote the 12 os and used it in a 2009 ctsv. This thing has 1800cc injectors on full e85 it?s a beast and really don?t want to just do a sd tune on it and like to keep the maf if possible. I know tune scaling is an option but one thing I?m not very familiar with as I?m doing a lot more late model stuff now or simpler combos on the earlier stuff.
    Thanks for help
    First 9 second 6th gen lt4 zl1 stock blower SHC SBE boost only.
    2013 cadillac ats 2.0t Big turbo-gone
    2007 tahoe 5.3 lsa blower on 14 lbs boost 6l80e swap 2009 os
    2017 zl1 a10 big gulp/2 inch headers/ 9.55 lower/ e85/bigger hx /103mm tb / Synergy trunk tank and underhood kit/methanol injection with torqbyte controller and prometh pump / Jokerz performance R&D ported stock blower/ lme cnc heads /GP tuning custom cam. So far 9.30@150
    What maf are you using? I would switch it to a ZR1 maf, has a much higher limit
