Results 1 to 6 of 6
Thread: Can someone look my tune over and see if I missed something
    Feb 2019
    SD
    26
    Its a LQ4 with 243's TBSS 2010 flex injectors. Timing goes -20 at start up and after it goes into CL the trims are everywhere
    03 Chevy Express 2500 6.0 4L80e TBSS Flex Fuel 2010 Flex Injectors.hpt
    13,585
    Did you use the excel spreadsheet to put the data into the LS1 format?
    Are you using the GEN 4 style MAP sensor?
    Is this a cable throttle body or drive by wire??
    Can you post a log file?
    Feb 2019
    SD
    26
    If you're referring to this excel >> http://files.hptuners.com/support/Ex...orscalels2.xls << it doesn't exist
    Gen4 map tune was changed to 128.20 kPa
    Wire
    I'll post up a log tomorrow, I don't know where the one I had went
    13,585
    I was meaning the injector data spreadsheet.
    Use this to copy the GEN 4 data into and it will spit out the GEN 3 format you need for it.
    Feb 2019
    SD
    26
    Supernova.xlsx I used this one
    Feb 2019
    SD
    26
    Here's a log, this time timing didn't drop like before. ignore the misfires I forgot I had higher the detection and forgot to change it back
