Results 1 to 4 of 4
Thread: Injectors for LSA supercharger install quick question...
    Jan 2020
    5
    Piecing together parts for an LSA supercharger install on my L92. I don't have injectors yet and was trying to decide between the stock LSA and Deatschwerks 50 lb/hr (16u-00-0050-8)
    Looks like the stock LSA injectors (stock 2015 ZL1 tune data shown) flow around 53 lb/hr at ~58 PSI
    And the Deatschwerks data is 61 lbs/hr at 58 psi.
    LSA injectors are selling used for ~$300 right now, and the Deatschwerks are like $500 new.
    Seems like this would be a way to give me a little room in injector DC without hitting my 63 lb/hr limit on my E38 ECU and having to do the half flow double stoich hack. Or am I missing something? I'm starting with the stock pully and with the smaller truck crank pulley I'l be at 5-6 psi. I don't ever see trying to push this blower more than 9 psi as I don't want to deal with the heat plus I'll be on a 6 rib belt.
    Thanks!
    13,559
    I'd probably go with the larger injectors.
    Advanced Tuner PGA2B's Avatar
    Nov 2004
    St. Louis, MO
    474
    +1 Larger
    2013 OBM A6 CTS-V Coupe
    Mods: Headers back Billy Boat Exhaust, GripTec 2.65, 8.6 PowerBond Lower, LSX Innovations Solid Isolator, ID850's, NGK TR7IX's, Accel 9070CK Wires, Spectre CAI, SRI Ported Throttle Body, SRI Catch Can, NGK AFRM, 160* T-Stat, 0fx2gv Brick, Hard Line Delete W/3/4" Lines, FB 101 FMIC, Pierberg CWA50, Stoptech Drilled/Slotted Rotors, EBC Redstuff, Cut Stock Springs, Flat Bottom Steering Wheel
    2006 Black Raven STS-V (Traded In)
    Fully Modded: 459RWHP@5888rpm/451lbft@4696rpm
    Tuner 5ft24's Avatar
    Mar 2018
    Sedro Woolley, Washington
    110
    definitely go larger. you want to have room to increase, not have to swap injectors again later if they won't cut it.
    and the scaling isn't a big deal.
    2006 Pontiac GTO
    M6
    Flex Fuel enabled
    FIC1000 shorty Injectors
    DW300C Fuel pump
    UPP GTO Auxiliary fuel system
    BoostDistrict LSA Conversion
    BTR Stage 3 PDS Torque cam and kit
    Kooks Longtube headers with High Flow Cat mids
    BoostDistrict LSA CAI with LS7 MAF module
    Mickey Mouse Catch Can
    Hinson 1/2" lowered Engine Mounts
    Magnaflow 3" Cat Back Competition Exhaust
    PLX DM-6 Wideband
    Turbo Technologies Full Flex fuel Tune
