Results 1 to 5 of 5
Thread: Updated to Latest VCM Suite - Help with Errors!
    Jul 2007
    16
    Just updated from VCM 4.4 (which had no errors) to the new version 4.8.7.0 which immediately throws these errors.
    The stop working messages appear upon closing either program in the normal way. After clicking close on the error message the programs then close. They start and open ok.
    The update check failure appears during a check.
    Win 7 pro OS. Everything on the machine is working normally.
    Are these just bugs in the new release that need to be fixed???
    7,627
    Set 'compatibility mode' to Windows 7 for both .EXEs (yes I know you're already running Win7, don't ask me, but that's what fixes it).
    Jul 2007
    16
    Thanks blindsquirrel. That did the trick for 3 out of the 4 errors.
    Now the Editor only still throws the update check send failure.
    Strangely in the middle of half a dozen test tries it made the update check correctly once.
    I guess I should email support and report this as a bug?
    7,627
    The update check thing sounds like a internet thing local to you. It works fine here, same Windows and same VCM version.
    Jul 2007
    16
    Yes but since the Scanner program checks for the update ok and only the Editor has the error it would not seem to be an internet problem?
