Results 1 to 13 of 13
Thread: Weird timing delema +4 knock
    Tuner in Training WildHorse's Avatar
    May 2020
    40
    2017 Mustang GT. Pump 94 octane. Just tune / CAI / off road catback. WOT hit in 3rd. 3000 rpm - 4100 rpm added 3 degrees added. 4200 - 7300 took away 3.5-4 degrees. Added 1/2 degree at 6000 another 1/2 degree at 6700 all the way to 7300 for a 21.5 - 22 degree total timing. Normal should be 26-27 degrees I think ? Could it be bad gas ? False knock ? Fuel trims are bang on with the PMAS. I figured with bad gas it'll remove timing from everywhere ? Otherwise it pulls like a freight train. Thanks for any input.
    Edit: Upon further review, I think I seen what's going on. Seem on the 'hit' it went +3 and timing dropped to 21.5 Tried to add -3 for a few hundred RPM, then went back +4 above 5000. So that means bad gas if I'm reading it right ?
    Apr 2018
    605
    Seems pretty low for N/A. I got around 27 degrees pretty easily with 93 octane on a stock Gen1 in 3rd @ WOT.
    Run that gas out and try a different station. If it still does it you may have false knock or some other issue going on.
    Knock Retard is the reduction or prevention of knock by lowering ignition timing:
    (+) Adding Knock Retard = Reducing Timing. PCM is seeing knock.
    (--) Lowering Knock Retard = Increasing Timing. PCM isn't seeing knock.
    __________________________________________________ ________
    2014 Mustang GT Premium. VMP Gen2R Supercharged with an FTI 3000rpm Converter. JLT, BMR, Steeda, Viking, etc.
    Don't fix it if it ain't broken | Maximum effort gets maximum results
    Mar 2020
    Western Canada
    91
    What is ur lambda during wot? I see 25-27 from 4500-redline(7600)
    May 2020
    40
    Quote Originally Posted by Cranked Automotive View Post
    That was the problem. It was tryna maintain a 14.6 stoich at WOT. Thanks for the hint.
    May 2020
    40
    Any reason for it not going into power enrichment @ WOT ? Thanks.
    Mar 2018
    447
    "That was the problem. It was tryna maintain a 14.6 stoich at WOT. Thanks for the hint."
    I don't understand, Ford uses lambda, stoich = 1
    So are you commanding WOT 1?
    It should be something like .83
    Mar 2020
    Western Canada
    91
    What made you adjust the power enrichment/wot fuelling parameters? I use 0.85 for wot. Stock settings start at 0.85 and richen to 0.825 or something like that as the rpms climb.
    May 2020
    40
    I didn't adjust anything. Just trying to figure out where my tuner 'messed up'. Anybody have the stock fueling tables ? Thanks.
    Mar 2018
    447
    You should be able to find one in the tune repository
    May 2020
    40
    Quote Originally Posted by K44 View Post
    I don't have an account there or have a registered device with them.
    Mar 2018
    447
    What year coyote do you have
    Mar 2018
    447
    Here is a 2nd gen
    May 2020
    40
    Here is a 2nd gen
    Thanks for the help guys !! Ended up being some messed up torque tables. All's perfect now. Again, thank you.
