Originally Posted by
Creton
How low can a VE table be set?
I have 5.7 ram, FBO, Cam, full exhaust. Recently i did a 6.4 intake swap, retaining the 6.4 injectors. It has been running very rich of course, so i tried to dial in the injectors and still couldn't get it to run right, was close, but just felt flat. I started tweeking the VE tables in hopes of getting it running better. I have reduced my VE tables by roughly 60% from the original value. The truck is running great, but my question is how low can you go on the VE tables before it adversely affects performance?
I've tried using the scanner to log with using the graphs included with the courses, but it will only populate zeros in a the cells. I can get STFT + LTFT to populate on the scanner.
Would someone please take a peek at this and offer some direction.
Thank you,
Creton
