Results 1 to 8 of 8
Thread: p0068 still after boosting
    Oct 2017
    25
    if you fast forward to 10.50 in to the drive you will see it goes int to limp mode... any ideas wood help
    Jul 2012
    Florida
    1,424
    According to the scanner, you are at 15# boost at 2300 rpm and 2.33g of cyl airmass and 51% throttle. That doesn't look right. Can you post a copy of your tune? What map sensor do you have?
    2013 Silverado 5.3, 6L80k 8.8
    post tune
    Calibrator By Day, Student of the Game at Night.
    www.LSXedit.com
    Want to Learn Hands On? I Offer Remote Tuning Email Me at [email protected]
    TEO TUNED
    You Can View Most of my Library on Instagram
    Website Coming Soon...
    INSTAGRAM: @TEOTUNED
    What are the modifications exactly? Have you changed the throttle body?
    www.LSXedit.com
    TEO TUNED
    Oct 2017
    25
    stock motor bigger injector 70 mm turbo
    Oct 2017
    25
    sorry for the delay.. it might be boosting past the 2bar map capabilities i have a intake blow off value and exhaust waste gate. my truck is a 04 silverado and if i remember right 2 bar is max for the ecm. is there a way to get past this i heard of people doing it but dont know how
    Oct 2017
    25
    i have posted tune and that is correct boost goes way up there at half throttle i have a manual gauge to verify running cts stock map sensor
    Jul 2012
    Florida
    1,424
    What is the part number of the map sensor? Your 55# injectors are probably too small for what you are doing. Monitor injector duty. Your PE table is a little off. If you are hitting boost at 2400, then you need to be in PE earlier. Do you have a boost referenced regulator?
