2006 chrysler srt8 p0614 - ECM / TCM incompatible
hi i have 2006 chrysler 300 6.1L and when i scan the PCM ECM it always throw 5 codes i always clear them with my hptuner and they cam back and some times when i drive engine stall / i did replace my tcm 2 times still the same malfunction
p0614 - ECM / TCM incompatible (pending.current)
u0100 - lost communication with ecm/pcm A (pending)
u0103 - lost communication with gear shift module (pending)
u110b - (pending.current)
u1118 - (pending.current)
i have tuned file and i have stock one i tried them both same malfunction i dont know what i should do i dont want spend money replacing for nothing
do you think my pcm have a malfunction and i should replace it?
Check for wiring issues , if you replaced it twice and issue presists that means other factors are involved
yes just checked for wiring nothing show any issues and i searched in webs for p0614 some sites say most common issues for this code is from pcm so i think i will change it and see what happen
