Results 1 to 4 of 4
Thread: turbo 5.3 rough idle base tune. HELP!
    Sep 2020
    TEXAS
    12
    fired up my turbo 5.3 a few days ago.(im fairly new to tuning, started tuning about a year ago) im having trouble tuning the thing. Idle seems to be rough. when I give it a bit of throttle in park the rpm drops and it wants to die then smooth out, give it throttle while in gear, it dies... Any advice or feedback is greatly appreciated.
    rundown on my setup
    5.3
    216/220 112 lsa cam
    SEP 80lb injectors
    76/75 turbo
    2 Bar map
    80e 3200 stall
    Thanks in Advance
    What are those injectors? Did you get data for them? What are they rated at? What fuel pressure you running?
    Calibrator By Day, Student of the Game at Night.
    www.LSXedit.com
    Want to Learn Hands On? I Offer Remote Tuning Email Me at [email protected]
    TEO TUNED
    You Can View Most of my Library on Instagram
    Website Coming Soon...
    INSTAGRAM: @TEOTUNED
    Sep 2020
    TEXAS
    12
    snake eater performance, yes i got the data, i used it and it would not fire up, crank no start. i posted the data in the other post i made. stock rails and regulator(58psi) injectors are 80 at 43.5psi. someone else replied on the other post saying to use the injector data i received, going to give that a shot tomorrow.
    I wouldn't rely on the data from them. I've even had trouble as of late from data from reputable Injector companies. So far, the only one I'm sure that truly has accurate data is I.D. That being said, you can try to make it work with the IFR table and min injector pulse width settings
    www.LSXedit.com
    TEO TUNED
