Whats up with this tune that the tuner set stoich to 24.23? Its a turbo 6.0, no blow off valve or intercooler. Also... seeing 84kpa at idle and what would seem like low idle timing?
I've read a few times there is a lazy way to tune AFR but not experienced enough to know where they are making up for this 24.23 commanded AFR?
Is the lack of BOV causing higher than normal KPA at idle? 6.0 - 4L80 - P59 - 210's - Turbo Stage 2 - 7875.hpt9-24-2020 #2.hpl
Also, he was told to run only E85 and the sensor is disabled. This tune did make 516 to the tire before it ran out of pump.
