Results 1 to 3 of 3
Thread: Dialing in low RPM airflow, in MAF and SD, truck wont idle now.
    Aug 2020
    29
    I tried to find a thread on this.. Couldnt find anyone else with the same issue.
    I got closer to getting my MAF and SD tunes both near lambda.. I always multiply by half..
    My cells in the idle range were showing lean, both in SD and MAF.. So the last time I tried to make adjustments in either mode, the truck wouldnt stay running. Dies as soon as I let off the pedal- even with idle set at 1200 rpm.
    I got a cam with 228/232 duration @.050
    Not sure what's going on... Any ideas?
    Aug 2018
    293
    Probably need to increase idle minimum final airflow
    Aug 2020
    29
    A 20% increase worked. ��
    Now if only I could get it to idle below 1100rpm ��
