Hey guys this is my first time in this gen3 forums I have a simple question when you want your throttle response to be faster or earlier do you follow the same method like gen4 or is it different cause on gen4 under airflow >electronic throttle >desired throttle area I think Map A normal.
That's usually where to adjust your pedal to be more responsive right but with gen 3 you basically have the same but instead of map A .....etc you this normal vs alternate is it the same or do you need to change something else?
