Results 1 to 3 of 3
Thread: Swap won't go into PE.....cannot find the culprit
    Thumbs down Swap won't go into PE.....cannot find the culprit
    Hi gang....I have done quite a few gen 3's but, I recently worked a gen3 p59 pcm, on a swapped lq4 in a range rover, with a 6l80 on a standalone controller that stumped me. Tuned up OK but...I cannot get it into power enrichment for the life of me.
    Raised and lowered all the delays and thresholds for TPS/RMP and MAP but, will not activate. It has a speed sensor input so is moving into the different fuel trim cells......so what am I missing? Log and tune below, need PE to finish it.
    Most searches had advise already tried...so reaching out here. Cheers!
    lsg10 blended NO PE wtf.hpl
    lsg10 OL blended just before hand off back to CL w o2s.hpt
    My guess is the open loop eq table being set to 1.0 hot is keeping it down
    13,582
    That wouldn't be the cause because the PE value is richer than the 1.00 stoich value in the open loop table.
    Is this vehicle using the throttle body, tac module and pedal from the same vehicle that the computer is from??
