Results 1 to 18 of 18
Thread: DQ250 TCM (DSG6) - MFD Current gear display
    Mar 2015
    Brazil
    51
    Hi everybody
    A Quick version of the Story,
    Before flashing the Stock updated version of the transmission, my car used to display the current gear next to the "D" or "S" indicator on the top right side of the MFD (D1, D2, D3, S1, S2...),
    After installing the updated software version it displays only "D" or "S".
    Does anybody knows how to enable this function again ?
    Thanks !
    Jetta TSI 2016 - Stock.hpt
    Jul 2019
    Wilmington, MA, USA
    155
    Did you update the transmission software yourself or was it done by a dealer?
    At least on my Audis ('12 A4 and '14 A6), that functionality is enabled/disabled via a transmission adaptation value with a VCDS (aka VAG-COM). If you have a VCDS, you should be able to Google or poke around some forums to see how to enable that function for your car. For example for my A4, it's:
    Code:
    Enable Automatic Gear selection shown in DIS
    [02 ? Auto Trans] [Adaptation ? 10]
    Select ?Single Gear Display? from top channel drop down menu
    Select ?D on/S on? from New value drop down menu
    If the VCDS route doesn't pan out, try changing the "gear over CAN" dropdown option under Trans Diag. I haven't had a chance to try this yet, but it looks promising.
    Previous
    2007 Mustang GT w/ Whipple supercharger
    2013 Focus ST
    2016 Volkswagen GTI
    Current
    2019 Golf R
    Mar 2015
    Brazil
    51
    Quote Originally Posted by ELaw View Post
    Code:
    Thank you for the Information @ELaw
    The transmission update was done by the MPVI2 Interface automatically in order to enable tuning, by doing this i lost the previous tune.
    i Do have VCDS, so will do some research about it !
    I'll come back with the results !
    Quote Originally Posted by Exley View Post
    This is exacly what i was thinking about, will give it a try and return with the results
    Mar 2015
    Brazil
    51
    Unfortunatelly, no luck with this one, in fact it's even worst, on both options (Active and Always on) the gear is not displayed even when in Manual Mode
    Will try with the VCDS.
    Mar 2015
    Brazil
    51
    Exciting news guys,
    Just received an update from HPTuners support about this.
    They've added the Gear display function on the new VCM Editor Beta.
    The function is under Shift General > General > Gear Display Normal/Gear Display Sport
    Quote Originally Posted by Cyboula View Post
    Exciting news guys,
    Very cool!
    Previous
    2013 Focus ST
    2016 Volkswagen GTI
    Current
    2019 Golf R
    Jul 2019
    Wilmington, MA, USA
    155
    Seems like they haven't added it for all variants. I just opened the files for my '12 A4 and my '14 A6 and that parameter is not available for either.
    Sep 2019
    37
    Your A4 and A6 arent dq250. This post was about the dual clutch transverse gearbox. You have the ZF regular automatic in those cars.
    Jul 2019
    Wilmington, MA, USA
    155
    Doh... I guess that would explain it!
    May 2014
    USA
    447
    Well, I have a DQ250 and don't see it either on the latest beta. Tons of different box codes, so might take awhile to make it to all of them perhaps.
    Mar 2015
    Brazil
    51
    Well, even after changing the option to Enabled, the gears still not showing up, just updated the ticket and will come back with the updates.
    Just to add info. I flashed my DQ250_0D9 and the gear display was enabled after the flash. I didn't change any settings related to this, so it seems to be the default on my base file. Not complaining, would have set it up this way anyway
    Previous
    2013 Focus ST
    2016 Volkswagen GTI
    Current
    2019 Golf R
    Mar 2015
    Brazil
    51
    Thats awesome !!! Hptuners team asked me to flash it again ensuring that i have the latest Beta, will try later today and come with the results
    Mar 2015
    Brazil
    51
    Updating this topic !!!
    The Last VCM Editor (BETA) now has a "Gear Display 1-6" Funcion over Transmission > Shift General > General.
    After changing it to 1-6 mode, the gears are being displayed (Without the D or S before, but it's already a big improvement) !
    Wasn't able to test the "Multiplex" and "Always Multiplex" modes yet, maybe one of theese is the one i'm looking for
    Sep 2020
    USA
    12
    Not showing on my 2015 GTI (DQ250) TCM file.
    Submitted a ticket.
    Mar 2015
    Brazil
    51
    Big update guys !!!
    HPTuners just released a new beta version with the 39395 parameter BOTH and ALWAYS BOTH option.
    Th BOTH option just completed the task !
    Now the MFA shows D1-D6, S1-S6 and goes to 1-6 as soon as i go to manual.
    So case solved !
    Big update guys !!!
    So case solved !
    Nice! This is visible in my DQ250 calibration now as well.
    Previous
    2013 Focus ST
    2016 Volkswagen GTI
    Current
    2019 Golf R
