Originally Posted by
32vape
My 1le does the same thing. If you log immediate torque source, you'll see it oscillate between none and axle. While in axle control the timing drops significantly. If you lower the vtt in the cruise areas of maf and airmass you can get it pretty smooth while driving steady state. I have also tried relentlessly to fix the pulling away from a stop in first gear timing sawtooth. Again the vtt tables will change how low it drops. I cannot completely get rid of it though as pulling to much torque out of the vtt in those areas makes throttle inputs overly sensitive and inconsistent. Not sure of the GM strategy where it switches to axle control on light throttle and in the instance of pulling away from a stop. Has to be a torque limit or multiplier table we're missing in the software.
