Background Info: (TL/DR) at the bottom
I've got a little bit of a strange question and the answer may be that it's simply not possible, but it never hurts to ask. I have a 2011 GMC Sierra with the high output alternator option. I have recently installed a power inverter under the rear seat so my kids can plug in all their electric gadgets while rolling down the highway. The inverter is turned on and off with a relay with the ignition switch and everything works great..... until this morning that is.
This is the first time I've driven the truck on a "cold" morning (~48?F) since I have installed the inverter. As is usually the case on cold mornings with most vehicles the charging voltage is higher than it would be when warm. When the charging voltage climbed to around 15v, or a touch higher I don't have an exact number, the power inverter started squealing due to too high input voltage. As it is mounted permanently under the rear seat I don't have a good way to just turn it off, and I wouldn't want to use that as a solution because there is a very good chance it will be used on a cold day at some point. I feel like on even colder mornings, which is a very real possibility here, that it will only become more common. So the best answer seems to be to lower the voltage to the inverter a touch. I'm posting here due to the fact that the truck has the adaptive charging, I was hoping a software solution might be available. I'm looking at the tune and I see a few max voltages but not any kind of overall system voltage upper limit clamp. I might can tinker with the duty cycle and get a lower number but I feel like if I had a high electrical load that might hinder charging. So finally the question:
TL/DR:
Is there a way, in software, to put an upper limit on the charging voltage? Currently it can exceed 15v and I would really like to clamp it at around 14.9v.
Thanks!
Edit - If I'm understanding the verbiage correctly in the software, the voltage is actually controlled by the BCM and the ECM can override that if required, thus there may not actually be a way to lower it. Can anybody confirm or deny?
