Results 1 to 3 of 3
Thread: Sky Redline Boost by Gear
    Sep 2020
    2
    Manual transmission. I need to lower boost in first gear as I'm loosing traction when using launch control. I've checked the % vs RPM vs Gear but the gears listed are 0 1 2 4 5 6 7. Does anyone know which gear I'm supposed to be changing?
    there should be a map for torque allowed by gear from 0-100%. but i am not 100sure it's available in HPT
    Sep 2020
    2
    I do see it, it's called % vs RPM vs Gear . Problem is I don't know which one is 1st gear on the Sky Redline. Some say 0 is Park or Neutral and 1 might be reverse. Other forums indicate 7 might be reverse. I have made changes to the percentage on 0 and 1 but seem to loose power on 3rd gear at about 6k rpm.
