Guys,
I'm fighting an issue with DFCO when Dynamic airflow is enabled... Working on finalizing driveability of the car...When I tuned on the dyno engine made 555WHP/490WTQ on E75 (Katech Stage 2 engine)
When I do a quick throttle tap or WOT then off at low medium rpm, the engine sometimes does not go to DFCO. Injectors keep dumping a ton of fuel, lambda goes to 0.55...
Airmass show crazy values (0.54g with 0% throttle)...Commanded Lambda is at 1.00
In MAF only I don't have the issue. Also when I disable DFCO and have Dynamic Airflow enabled it almost never happens.
I think there is possibly an issue with my VE table (tuned to 3-5%) but I don't understand what exactly... I saw that when I happens I have a pretty big discrepancy between MAF airFlow (10g/s) and VE airflow (14.5g/s)... But even at 14.5g/s my injectors should not dump so much fuel (2.8ms !!! )
Looking at my log and tune do you guys see an explanation ?
Also I have the butt feeling the car has more torque down low when dynamic airflow is enabled compared to MAF only ???
