I have a 69 Camaro with a LT4 8L in to be tuned from another shop. Started working on it and noticed a 30-40% trim increase on B2. Swapped sensors bank to bank and issue stayed on B2S1. So I did all the basics, wrung out harness checked grounds, smoked intake and exhaust. All good. So I installed my wideband in bank 2 and sure enough getting .73 lambda at idle. O2mv stuck at .9 on bank 2 only. So PCM is doing what it is supposed to do. B1S1 is nearly perfect with a 3% trim at idle. Had a spare PCM and swapped it no change. BTW this is a GMP Crate deal with control pack. Can't for the life of me figure out what's up. Anyone run into this?
