Hello,
Spent half day testing differnt settings and problem not solved. 2008 3500HD (duramax/allison), gear ratio changed from 4.10 to 4.88 and ABS + brake light comes on at 30mph. Tried the gear/tire wizard, tried keeping the ECM side stock as well as some manually calculated values but no luck. Calibration is strage from factory with 3.73:1 in ECM and 4.10:1 in TCM. Attaching file, any help would be great. I have only until tomorrow to solve it and then vehicle will be far away.3500Dmaxstock.hpt
