Results 1 to 5 of 5
Thread: Odd reduced engine power, '17 Chevy SS, no codes
    Baltimore, Md
    1,208
    Started doing this and it was a long day so Im just missing something dumb Im sure. Just idling, driving, WOT whatever it randomly pops Reduced Engine Power - but doesnt actually reduce any power? Ended up turning misfires completely off on the chance it was popping up a couple here or there even after I had numbed them down but ended up same thing. Stock throttle body, not tripping past any airflow limits sitting still obviously
    Other thing I just noticed going through log was random knock retard that just held and didnt decay in a no load situation - all burst knock is turned off already
    Factory Stock 97 SS M6 13.51 @ 104.3 mph
    Stock Longblock LS1 w/ 233/238 P.S.I. Cam
    10.81 @ 126.9 Full interior, six speed on 275 radials, a decade ago
    '99 TA trunk mounted 76mm 6 Liter
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    32psi and still winding out 5th on the highway somewhere
    Oct 2016
    36
    I had my ls3 C6 going into REP without codes. It was caused by engine tq mgmt settings in the tune. I changed them back and it never happened again.
    Disable Tq limit 2 tab under engine-tq mgmt-general- tip in limiting. See if that helps.
    Also set brake tq mgmt to disable, set those settings back to stock but just disable the tab. (engine-tq mgmt-general).
    Baltimore, Md
    1,208
    Quote Originally Posted by Asd_srt View Post
    It seemed to be caused by removing speed limiter settings. Put all back to stock and OK?
    May 2017
    North Florida
    80
    Quote Originally Posted by GrannySShifting View Post
    I have this issue with a 2016 camaro ss. My speed limits are not maxed out. What values did you put back to stock? This rep dummy light is so annoying. Nothing is reduced just a light. Mine has even happened before even starting car.
    Baltimore, Md
    1,208
    Quote Originally Posted by Brianw36 View Post
    Compare to stock file and reset everything back to OEM
