We are having issues with getting a 2017 GMC Denali 8l90 to relearn. The procedure is aborting almost immediatly with low voltage codes popping up. With a voltmeter at the TCM it shows 13.5 volts and with our snap on scanner it shows the same. Hp tuner software shows the same, however it won't relearn because of the codes. We did a global reset twice.
We do the brake apply, lasts for about a minute then aborts. We do not see autofill and does say to put into any gears. It also does not increase engine throttle. No codes are in the ECM
Any thoughts or were to look first? Thanks!
