Currently running E85 and have enough fuel support for what my plans entail.
09 ZR1 with some bolt ons. hitting around the 750rwhp mark.
looking to really over spin the SC by adding the lower 14% OD ATI balancer (currently 2.2 upper). I am worried about heat in the SC and IAT2's going through the roof even with E85 and all the extra cooling mods (no ice tank though, want all the space in the cargo area as possible)
I've done my due diligence before posting and have read numerous methanol inj tuning threads and still have many questions.
-Looking at buying Alkycontrol MAF kit. thinking single M15 nozzle (targeting 800rwhp+ bolt ons only)
-I usually dont see ZR1 guys with IAT break out from the maf (dont want to hack up my Kong CF intake either). does the IAT2 table directly relate to and RESPOND quick enough for the IAT vs spark table to adjust my timing when it sprays and pull timing for when it fails?
-when meth fails, generally how much timing pull above 100* iat?
-generally how much timing to add below 100* iat for gas or ethanol (was thinking up to 3* at 70*)
-target 10.8:1 (heard best afr target when spraying) when meth is spraying?
-adjust fuel by pulling fuel from maf? or Iat vs map multiplier under fuel injector settings?
or spray so much meth that when it fails i had so much fuel pulled itll be so lean that it will stumble and thatll be my failsafe?
I feel like im on the right track but have never installed/sprayed/tuned for methanol inj before.
maybe im overthinking?
im just really trying to get the most power i can safely with what i have and hopefully pass the 800whp mark with bolt ons.
