Hummer H2 2006 -
Hi all,
I have problem to read hummer H2. I cant read ECM / there is fail.
After 20%, the dashboard switch off.
How can i fix it ?
best regards.
Usually voltage problems. Are all your grounds good and battery charged/good? Try hooking up a battery charger while reading.
I dont know how to dsable Retained Accessory Power (RAP) !
Pull radio and radio amp fuse in underhood fuse box.
RAP is only active after the key is turned to OFF position and all doors remain closed.
I Pulled radio and radio amp fuse, then bcm fuse...
I keep 1 door open. ... In Drive, in Neutral, impossible to read !
Then it's not RAP causing your issues.
Does the dash "switch off" if you keep the key on and not attempting to read?
Is it an aftermarket radio or does it have an aftermarket remote start?
its noises from the systems on the rig, I had the same problem, there are like 5 fuses you need to pull, then it will read, I'll go take a picture of mine and show you, pull all fuses with red paint pen on them, doors closed, HVAC off and it will read
