Originally Posted by
Jim P
Loaded circumference is the circumference of your tire with the vehicles weight on it and the centrifugal forces acting on the tire.
Don?t worry about it when it?s not locked up. You?ll just have to adjust as you see fit for converter slip.
Put the formula in user defined math, set your axle ratio, set your highest gear ratio, set your mph PID where it says mph and set your engine rpm PID where it says engine rpm, have engine rpm and mph set in channels, set the user defined math in charts and have it read average, get out on the road into the highest gear, locked up at like say 75mph and log it at that speed for a few minutes while in the highest gear and locked up.
Use that average with the first formula in excel to convert mph to OSS.
Don?t know about your truck but on the Cummins you change it in the editor, not the scanner, where it says pulses per mile.
