Results 1 to 5 of 5
Thread: throttle hang from 2k to 3k
    Ok issue with throttle hang around 2k up to 3k rpm range under light throttle. It will stay at the rpm it is at between those rpms when letting off and clutch in to shift . 6 speed 2016 challenger rt.5.7
    any ideas?
    Nov 2017
    818
    Is it stock?
    What did you change?
    Are you trying to get the bangy poppies?
    If in doubt, multiply everything by 1.1.
    Quote Originally Posted by spoolboy View Post
    Is it stock?
    No don't want any popping. rpm hangs between gears if between 2-3k rpm.
    stock 5.7 cam, long tubes, no cats, Holley sniper intake . I turned off throttle adaptation . will see how that goes but that seems to do the trick.
    Engine pulls hard to 6800 rpm
    Quote Originally Posted by Speed39 View Post
    log throttle voltage at the point that hangs the throttle and then raise that value in the throttle airflow model
    Quote Originally Posted by malikib View Post
    Thanks, I will give that a try.
