Running lean gen3 gm/Holden ss
mel v8 as found.hpt
Can someone please have a quick review of the attached files, new to tuning and appreciate some guidance as to the ltft , I note this vehicle has lean burn active that may be confusing me with its 1.2 commandeered eq lambda ratio at part throttle?
Any further suggestions as to any reading material would be great thanks
Noted tps only reading max of 60%, this may explain the o2 trims lean?
mel v8 as found.hptmel v8 open road.hpl
