14? GT Aftermarket Return Fuel System Readiness Monitor Question
Car has a return system and fails the fuel system readiness check. On 11/12 cars from what I’ve seen this isn’t too difficult of a fix. But on this 14 car it appears if the fuel system test does not run or does not pass, the catalyst test will not run from what I can see on a scanner.
Does anyone know where the ECM is pulling the test voltages from that show in the Mode 6 test? Has anyone seen the monitor successfully set with an aftermarket return system on a 14?
