Thread: Help with a 5.7 4x2 cherokee with cam! please
    Oct 2020
    Cool Help with a 5.7 4x2 cherokee with cam! please
    Hey guys,i cant do this alone.....tried a lot times.....
    I have a Cherokee 2006 5.7hemi and cam and a wide throttle body.....
    I get lambda on the wideband 1.10 to 1.60 on idle and light run..... lot poor!
    At WOT i was getting 0.90 poor to....
    So i get the VeBank 01 and VeBrank 02 and the PE tabbles X 1.15 or 15%
    The problem is.... my idle and open loop, stills on 1.10 and 1.60 ( tried X 1.30 ) still the same......
    But at WOT NOW I GET 0.80......
    Any owesome people to help a brazillian farmer that do all at is on, cause im on the middle of nowere!
    thx regarss...
    So how i fix that ?
    Nov 2009
    All Around
    3,149
    for any help
    post the file you are working on
    and a datalog of the issue
    Oct 2020
    Quote Originally Posted by SultanHassanMasTuning View Post
    for any help
    hey ok...
    Is a cherokee 5.7, im living on brazil so the all the fuel here is
    Composition: 73% gasoline A and 27% anhydrous ethanol *.
    We have easy here 100% ethanol, but i dont know if the injectors can handle this....
    My hemi has :
    COMP Cams 112-501-11 XFI
    And a 90 mm throttle body
    The air filter is oem, dont have the Ken inbox filter but i will....
    See the video the wide band is on lambda factor, very poor at idle....
    The log files was a little slow to get info....
    Nov 2009
    All Around
    3,149
    raise your idle speed for sure factory 625 not good
    you need to know the injectors installed as well
