chris timing 1.Channels.xmlchris miata main VE 15% increase across the board 1.6.19.hplchris miata main VE 1.15% change 1.6.19.hpt
LS 1 cam swap, Gen 3 hot cam. GM part number 12480033. duration .050 in. 218/227, lift .525/.525.
Used Russ K idle tune. Idle is OK. Any power over around 3000 RPM and the PCM pulls the timing out because of knock.
I've attached the Tune, log and channels.
Freely admit I'm new to this, any help appreciated.
