Disable Autostart
Bit the bullet and wrote a tune to make some minor adjustments on my 2020 F150. One of those small changes is to disable the auto start stop feature. So I went into system and disabled the option there but found that it seemed to work but then all of a sudden it would begin doing the auto start and stop again. I first thought it was an issue with the tune but I solved this my also disabling the idle auto start/stop. Doing this reliably disabled auto start/stop.
Just posting in case someone else also found that the master switch on the 19 and didn?t disable it fully.
I believe you need to disable it using ForScan.
I have successfully disabled it using the method above.
