Crown Victoria Low Park/Neutral Limiter
I was finally able to raise my neutral/park limiter on my 2011 Crown Victoria. I figure I'll post it to help anyone else that was trying to do the same as I didn't really find any info when I searched.
Under Engine: Go to Torque Management>General>Torque Max vs. RPM. Set all the values to the highest value in the table.
Mine were (stock):
442.53
442.53
442.53
221.26
0
-221.26
-442.53
-442.53
I changed them to:
442.53
442.53
442.53
442.53
442.53
442.53
442.53
442.53
Then go into Engine>Fuel: and raise the neutral cutoff to your desired rpm, I chose 5900rpm. Hopefully this helps someone else out.
What does that mean?
Can you explain that
thanks
