I have a AEM Wideband and have it grounded to the #5 on the connector.Has anyone hooked up another ground to the metal by the OBDII port but left the ground on the green connector also?I think I will give that a try today!
2018 GMC Denali A8 6.2L
2016 CTS-V
2016 C7 Z06 A8
2016 C7 Z06/Z07 A8 vert
2015 Chevy SS 6.2 LS3 A6
1996 Impala SS LT1 CAI
1995 Chevy 1500 5.3 CAI Z06 cam
1957 Chevy vert
I'm not sure but doesn't that create a ground loop? Oh, how isi the AEM working out for you? I've got one too. I currently have mine grounded along with the rest of my guages and my AFR isn't very stable, it's all over the map so, I've been suspecting that I need to ground mine to the EIO.
I HAD mine connected to the EIO MPVI on #5.
In the help files it shows that an LM-1 is grounded to the MPVI and thats it.
I was told you should ground it off NEAR the OBD II port. On something metal like for example the seat mounts and stuff like that.
Never heard of a grounding loop though
Ground what near the OBD port? The EIO #5?Originally Posted by slow6
All WB controllers should be grounded directly to the battery ground to avoid ground loops,voltage shifts, el noise. Just run speaker wire thru the firewall(pass side, behind PCM) to the battery ground terminal and be done with it. EIO5 is not power ground.
www.turbofirebird.com tuned with HPT MPVI Pro, LC-1.
Thanks!
I will give that a try!!!
2016 CTS-V
2016 C7 Z06 A8
1957 Chevy vert
