Results 1 to 9 of 9
Thread: 2018 silverado lean at idle
    this truck has a 5.3l with a magnuson tvs 1900 kn cold air intake speed engineering long tubes mbrp catback but currently lean at idle just hoping someone can help me calibrate the maf or get it close
    Apr 2014
    North Dakota
    64
    Set your Dynamic RPM disable down to 300 so it is MAF only at idle too.
    Add MAF frequency to your scanner so you can build a histogram and log LTFT+STFT into it. Then you can copy the trims as percent into your MAF Calibration to tune it.
    2014 Silverado L83 | Knockoff S369 Turbo | LT1 Fuel Pump and Injectors | MAST L84 Port Intake | MS3Pro Secondary Fuel Computer
    Quote Originally Posted by MORLOK View Post
    I have tried this earlier it seems with the maf unplugged it fuels normally no maf.hpl
    13,565
    Yeah but then your timing goes negative and that is not good either.
    I'd say you have a vacuum leak if both banks are that lean.
    I'd say possible if the truck didn't fuel properly after it starts moving
    have found a problem the reason it leans out quickly on bank 1 the y pipe clamp has come loose and pulled the y pipe back off the header and the vacuum from the passanger side is slowly pulling it down will fix and inform everyone tomorrow
    Aug 2020
    30
    Boost,
    I have this same issue currently I am going to swap to a LT1/LT4 MAF and see if that changes anything, ill keep you posted with my results, let me know what you find out.
    I broke the pcv at the front of my blower and didnt notice it due to my excessively loud exhaust replaced the fitting now the truck is super rich at idle need to take some fueling out but its working
    Quote Originally Posted by Reaper0001 View Post
    Boost,
    i had broken my pcv at the front of my valley cover replaced it and it works great now
