Been having issues with a '18 SS with the A8 transmission. I did a whole cam kit, dod delete, nw 102 throttle body and other supporting mods and I can't get this thing to shift properly. Predicted Torque Source goes to "RPM Limit" and it shuts the throttle before shifting and it completely kills the car. Spark and fuel aren't being cut only throttle closes down to around 42%. Torque tables are calibrated, driver demand as well, predicted axle command is higher than actual, predicted torque is higher than actual, messed with shift mph using the bluecat tool and nothing. Still getting that "RPM limit" under predicted torque source and throttle closure
