Results 1 to 6 of 6
Thread: Boost
    Oct 2020
    4
    Boost
    I've been tunning a walkinshaw Ute in Australia it has a supercharged 6.2 in it .when I go in to fuel system and click on maximum boost v barametric max press it's set on zero does this mean it's not making any boost and can i get away with setting it at 7psi without changing pulleys etc etc
    13,564
    Did you log the MAP sensor channel to see how much boost it's making??
    It should be reading north of 150-170kpa if you ask me.
    Changing that table won't do what you are asking.
    Oct 2020
    4
    Thank u I'll check it out cheers
    Oct 2020
    4
    I went and had a look at the tune as the vehecial isn't hear and map max is 105kpa so I'll write a conservative tune and flash it and see how we go thank u for your point in the right direction 😎👍
    13,564
    Are you logging the correct MAP sensor channel??
    You may need to remove the 1 bar channel and replace it with a 2 or 3 bar channel to read over 105kpa in the scanner.
    And make sure the vehicle has a 2 or 3 bar map sensor with the correct settings.
    Oct 2020
    4
    Sorry took so long to get back to u slipped my mind 3 bar sensor legend thank u
