Im wanting to swap from the closed Bypass valve on my 2020 sierra 5.3 with procharger, as ATI installed it back to the intake side. As a test I removed the tube and plugged it so no vacuum leaks were present. I let the Bypass valve just go under the hood. immediately got p0172 and p0175 both banks rich!!! So apparently the procharger tune is somehow using the Bypass pressure for extra AIR after the MAF sensor. Has anyone been through this? wondering if I should even attempt it!
My main reason is I am seeing some light surging at 1/3 to 1/2 throttle and watching boost and vacuum and listening I know it has to do with the returning of air after MAF. MAF is steady as a rock.
