Im at my wits end on this one nearly pulling my hair out. Ill start with the vehicle and the problem and go from there.
2004 sierra 5.3, 'built' 4l60e
-Stock motor
-gapped rings
-head studs
-FIC 650cc injectors
-electric fans
-aem wideband
-on 3 7875
-china bov & wg
-homemade hot side kit from stock exhaust parts
Basically from the beginning of the tuning process Ive been fighting the vehicle seeing knock and pulling tons of timing. To better describe the problem. The engine pulls hard and clean if I hit the throttle hard. If at any point I roll into the throttle it starts to surge and buck as the motor pulls timing. This makes practical driving and using it as a truck pretty useless.
Ive been having a very reputable shop tune it on a dyno here in southern Idaho. Initially when it happened I did have some spark plug wires not fully seated so I pulled the plugs to double check their gap (all set to .027) and replaced all 8 plug wires with new ones. After that the knock didnt go away so the tuner suggested I replace my injectors. He isnt a fan of anything not name brand and I had some refurbished deka 80s. I pulled the Injectors and had them flow tested at another shop which did show several of them to be 5-7% off. I got a refund for those and ordered a set of Fuel injection clinic 650cc's. During this process I had actually hurt the motor from a boost spike. Lots of blowby resulted in me pulling the motor and replacing 3 pistons with broken ring lands. With the new pistons came a full set of new rings gapped to .026 and I added hardened push rods and head studs. While the motor was out I replaced the knock sensors with AC Delco units and replaced the harness. Got the motor back in and trailered it once again to the dyno. Now the truck is idling better and is able to make clean pulls. On the dyno it did 520 hp 630 ft. lbs at 13 lbs of boost. I was pretty happy about that until my tuner told me that the knock problem is still there. I asked him if he would turn off the knock sensors to see what the motor did on a roll in and the power curve is very choppy until about 3000 rpms where it cleaned up. Ill add a picture of both dyno graphs. Next I got the truck home because I cant afford his rate to diagnose problems. After I got it home I met up with a buddy with his tech 2 to see what the computer would tell us. We drove the truck to the local airport and put 10 gallons of 100 octane av gas. The best fuel I can get here is 91 or 110 sonoco at $9 a gallon . Even with the higher octane the knock retard was still there. We even tried unplugging the knock sensors to see what would happen and you guessed it, still pulls timing. Ive read and read all I can find on the subject and everything I try doesnt do much to fix it.
I decided that I wasnt going to pay the tuner any more money just for him to tell me that Ill have to come back another time to have it tuned again so the plan is to begin the learning process of hp tuners and start to figure this out more on my own. I logged two pulls, one at WOT and the other rolling into the throttle so Ill attach those as well as a copy of my tune. I appreciate anyone giving their .02 cents in helping me figure this out. Thanks in advance
