sep 850 inj info needed. bear with me im struggling..
ok boys .
5.3 /th400 sep850s
slopy stage 1 elgin cam , billet 78/75 vs turbo.0411 pcm 3 bar os
ls6 map sensor. pump gas
Im really struggling finding a tune for this combo, seemed pretty common. Im pretty new to hp tuners and finding my way around.
I have it running and just threw som big numbers t the +105 kpa table.
seems to me the first step besides failing the maf is enetering the injector info. so far I just entered 85lbs per hour across the board n left everthing else alone.
does anyone know the proper injector values to enter? the 850s cae to me n.ib but second hand. I have the sheets that came with but they seem usless to me.
can some one point me in the right direction for a tune to get me closer , im worried about the fuel n boost timing, cant afford to po this thing learning. I have a wideband installed and once I can start logging I feel like I can get it dialed
SEP should have supplied the correct data
I have the 2 sheets but they don't make sense to me flow cc/min injector offset and duty vs flow cc/min also its at 43 psi. im running 58
Found it from sep , thanks
