Results 1 to 8 of 8
Thread: Gen 4 VVE histogram filtering out manifold position
    Feb 2020
    Tug Hill, NY
    4
    Not for nothing, is there a filter formula out there to generate a manifold open or closed specific histogram when dialing in vve? Not sure it even matters so much do try, generally ive always copied manifold open to the closed and it pans out close enough. Screwed around a bit tonight with using throttle position filtering against my error histogram with no luck which lead me to 3 hours digging through the threads, also with no luck. Any help/suggestions would be appreciated.
    Aug 2018
    294
    If you don't have a variable-length intake runner, then it's all the same, right?
    Feb 2020
    Tug Hill, NY
    4
    Have to check, but i believe so, that is all still stock at the moment. I mean correct me if im wrong but "manifold switch" is in reference to the actual throttle blade being in either open or closed position, where the length of the runners shouldnt matter, and the 2 vve tables would be applicable to throttle part open or closed?
    Aug 2018
    294
    The manifold switch refers to a valve inside the intake manifold that effectively changes the runner size/length for different RPM's. If you are running an LS motor with a standard composite intake and no manifold valve (all cars that I know of), I believe it actually uses the "open" table for fueling calculations, but everyone typically just makes the open and closed tables the same.
    Also make sure you're accounting for Injector Tip Temperature offset if you have non-stock injectors. It will screw with your tuning if not considered.
    Feb 2020
    Tug Hill, NY
    4
    Hum well that makes way more sense, i have yet to come across anything with that setup yet, just now catching up with the times on the gen 4 and 5 platforms so apologies for the incompetence. Havent stepped up injector size yet, thats next seasons project when we get into boost, just mild cam, springs, and long tubes, but will definitely take note of that.
    Jun 2014
    Boulder, CO
    202
    Quote Originally Posted by RobZL1 View Post
    Could you please explain this a little more or point me towards an explanation? Thanks!!
    Aug 2018
    294
    Quote Originally Posted by pannetron View Post
    https://forum.hptuners.com/showthrea...ip-Temperature
    Jun 2014
    Boulder, CO
    202
    Thank you!
