Results 1 to 20 of 29
Thread: AUDI/VW ZF8 TCU- Stock/Tuned Files (Repository)
    Thought i would steal the idea from the ecu repository thread and create a separate thread for the ZF8 TCU
    2011 A4 stock tcu 8K0927158S__1005
    Stock TCU file 2011 a4 8K0927158S__1005
    2012 stock A4 8K0927158S__1003
    2016 rs7 4g0927158bh_1005
    Sep 2019
    36
    Just an idea based on what I do is label the file with the year, model, engine or trans, and the actual part number as it makes it easier to identify later.
    Sep 2020
    7
    I like the idea. I think it would be worth noting what HW and SW version you have, which I think is what BB-TT has done?
    Sep 2020
    36
    Anybody got Q5 TDI stock pulled by any chance and could share?
    Oct 2009
    2017 Audi A6 3.0 ZF8-Stock Tune
    Here you go,
    Mar 2021
    7
    anyone got a tuned file for a 2015 SQ5? Looking for something that holds gears and is better than the stock file.
    Quote Originally Posted by ParisAudi View Post
    What vehicle do you have. Attach your stock file here.
    Mar 2021
    7
    Here's the stock file
    sent u a pm do you have an ecu tune? no point in increasing the shift point if the rev limiter kicks in before you shift. Have you logged which TCC patterns are being used in sport and manual? Mine using 3&8, and 27 &47 almost exclusively in sport and manual. i can point u in right direction but am not going to waste time modifying a bunch of maps/shift patterns if your ecu doesn't use them.
    Mar 2021
    7
    Quote Originally Posted by bb-tt View Post
    Totally appreciate it and yes I've got an APR stg 2 tune. If you can point me in the right direction, I'd be grateful. I don't think we need to worry about the rev limiter kicking in early, due to the tune, so really looking to leave the normal "comfort" as is, but change up the sport/dynamic and manual for sure. TIA
    starting a new thread this thread is for stock files
    Jul 2021
    Hey
    Does any one have stock or tuned 2013-2014 rs7 transmission file or tuned 13/14 s8 file
    2014 S8 ZF8 Stock 4H1927158EG_1002
    2014 S8 zf8 stock.hpt
    2011 q5 2.0 zf8 8r0927158e__0009
    Stok 2.0 q5 zf8 file 8R0927158E__0009
    2011 2.0 q5 ZF8 8R0927158E__0009.hpt
    Aug 2021
    10
    adding a 2016 S8+ stock TCU tune. Some slight differences with the rs7 map but the Max Map showed no differences.
    Apr 2018
    4
    So is it as easy as flashing/writing the s8+ or rs7 tcu file over my existing? I have 16 a8l w/ zf 8hp
    Aug 2021
    10
    Not that easy, you have to edit your maps and just put those values in I believe.
