The motor is an iron 408 with PRC247 heads, 11-1 comp, 231/243 .627/.615 113lsa cam, TBSS intake, and 87mm TB. It's in a 2004 Denali that's been manual transmission swapped several years ago and was running fine with a milder 408 setup. The truck starts and idles just fine even with AC but I have been trying to tune VE and its getting knock all over the place. I reduced the timing down to 1 in some of the cells and it still wants to pull several degrees which puts it in negative timing. Also while in SD it has a terrible bucking around 1600rpm, it isn't started by a shift or blip of throttle it just comes around right when you get to that rpm in 2nd 3rd or 4th gear. If it's put back into dynamic the bucking subsides substantially. Also, it hangs rpm around 2k when rolling in neutral or clutch pushed in while rolling. I have messed with TF, TC, and rolling idle which is what saved it from stalling constantly.
Heres both files please tell me why I'm an idiot and WTF I am doing wrong.
