Results 1 to 4 of 4
Thread: Impala: Bunch of Codes - Pic - HELP
    Apr 2006
    2
    Hey guys,
    The check engine light on my parents 3.8L 2001 Impala has been on for awhile, so I decided to hook up HPT to it when I had some free time and read the codes.
    This is what came up:
    For the past little while the car has been hesitating under acceleration, as well as having an eradic idle, especially at start up. I thought it was a fuel issue ... either the filter or pump ... as something similar had happened before about a year ago and changing the filter fixed the problem.
    With these codes, however, I dont think it is the same problem.
    Any input/advice is appreciated. =)
    BTW - sry if this is in the wrong forum.
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    P0102 is the code to check out, is the maf unplugged? If not you will need to find the cause of this code, bad maf sensor? As for the other codes, those are body & loss of communication codes, don't worry about these as almost every car that I scan has a bunch of these codes.
    Russ Kemp
    Apr 2006
    2
    Thanks for the heads up ... now I know what to concentrate on.
    Advanced Tuner Screamn03's Avatar
    Feb 2004
    Vacaville, CA
    832
    The ones that start with P are the ones you are interested in, just in case you get a different code in the future. Transmission codes I believe start with C.
    -Michael Rudolph-
    2003 Redfire Cobra
    Eaton Powered to a:
    11.301 @ 129 1.68 60' MT DRs
    11.85 @ 124 1.90 60' street tires
