Results 1 to 5 of 5
Thread: Upgrade LS3 MAF to LS7 card style E38
    Jul 2019
    Baytown, TX
    118
    Hi, Search must not be my friend today.
    I've got a '16 Chevy SS, LS3, Whipple, TSP Stage 3 CAM, E85, around 10psi... its approaching 700WHP and I'm still running the stock LS3 MAF, airbox and a K&N Drop in that came with the Whipple.
    I purchased a new 4.5" Synergy intake, it has the LS7 card style MAF.
    Can anyone help me out with a good base MAF vs Freq table to get me started? I believe I can handle fine tuning of it.
    I've lookked through the repository at some 2008/9 LS7 corvette files, but the actual MAF range in these LS7 files look smaller than my file, plus they have high and low tables, even when i put them together in Excel the range just looks completely different (and smaller) than mine.
    I had thought about failing the MAF and running in SD to let me log actual measured MAF freq at various airflows as a way to build a table, but not sure if that would work, the car was calibrated and running well in both MAF and SD before I started with the Synergy install.
    I've attached my current calibration.
    2016 Chevy SS M6_6.2L_Whipple 2.9L 3 bar 231-239-115 ID1050x wFlexFuel.hpt
    Thank you!
    2016 Chevy SS Sedan M6 SBE LS3, Whipple 2.9L, 3.625 upper/stock lower pulleys for 9.5psi, TSP Stg 3 SC Cam, ID 1050x injectors, LS7 MAF, DSX Aux Pump, DSX Flex Fuel Sensor
    2009 Dodge Challenger SRT8, 6.1 HEMI, Edelbrock E-Force TVS-2300, 9psi
    Jul 2019
    Baytown, TX
    118
    cancel request, i looked up the new LS7 MAF's p/n on internet, found it was used in the '15 Camaro with 6.2L so i got a curve from the repository off a posted stock '15 Camaro... idles well, super lean, but trims controlled it, so I can start logging data and adjust the MAF now... thanks anyway!
    Aug 2009
    Calibrating
    3,373
    MAF tube size is the trick... larger tune the MAF values need to be increased basically
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Jun 2010
    559
    Quote Originally Posted by Ben Charles View Post
    Ben I was about to look and search about this mod, using the ls7 MAF. Using this ls7 MAF in a 2008 tbss or a truck e38 ecm it?s like we have to start a new maf curve, tune the MAF?
    Aug 2009
    Calibrating
    3,373
    Yea ls7 works great on Trailblazer!! Add 25-30% and will get it close and dial in the MAF
    14 Gen 5 Viper
