Using original E38 ECU and Trans T43. Operating System 1250228. Reprogrammed to remove VATS and delete monitoring un needed DTC's. New Harness and programming by BP Automotive. Engine on test stand. Fully charged battery, Ignition Switched from TS Control panel. Power to IGN wire in Harness. Starter Switch press to start direct to Starter Solenoid. All wire harness items needed attached. Function verified on IGN, START, FUEL PUMP, Cooling Fans, Trans cable attached to trans (on separate stand). Original problem was no fire or fuel. Traced to miss-wire on CMP sensor, signal A and C reversed. Engine now fires, runs for about 2,3 seconds and shuts down. No throttle response (throttle operation verified) After starting won't start again unless it sits for some time before the next try. Sounds like classic VATS problem. VATS is disabled in both positions in SW. I can't find anything in the SW that points to a program problem.
Anyone have any ideas?2009 Pontiac G8 E38 BP Tune.hpt
