Results 1 to 3 of 3
Thread: 2004 Z06 Histogram
    Apr 2020
    27
    2004 Z06 Histogram
    Trying to help a friend out on his new build, He got a email tune and its running very lean.
    Wanted to just log his tune see what's going on before adjusting anything. Im confused not sure what im doing wrong, im not getting any data in my histogram for MAF HZ. Hes going to order a wideband to make sure everything matches but wanted to get my Histrograms and Pids ready before tuning.
    Mods
    ls6 with comp cam
    Cnc heads larger valves
    Vararam
    13,565
    Graphs/charts don't read if the channel isn't being logged.
    Add the MAF hz channel in the logs and the graph will populate with data.
    Compare the MAF/VE tables with a stock tune. If for whatever reason the MAF/VE have lower values in the tune that could explain the lean issues the fuel trims are showing. The VE table to me doesn't look right.
    Also make sure there are zero intake leaks with the aftermarket intake.
    Apr 2020
    27
    Thought I had it logging. I'll add that pid, the ve doesn't look right to me also. Comparing to stock i found in repository. The VE tables are quite a bit less.
